Towing a Trailer? "New Product"
scot w.
GNSperformance.com
GNS Performance is the first authorized dealer to carry RideTech's new "TowPro" system for trucks!
Load Leveling Made Easy!
It should not be surprising that small, lightweight cars should have soft springs, and large construction equipment should have beefy, stiff springs. But what about pickup trucks? These vehicles can operate with no cargo at all (no weight in the bed), or with thousands of pounds of cargo positioned over the rear axle. Ideally, the leaf spring of a pickup should adjust between soft (no cargo), or stiff (maximum cargo). Unfortunately, traditional leaf or coil springs are only sized for one loading condition. Fortunately the TowPro fixes this problem.
The new TowPro kit is installed between a truck’s leaf springs and frame, supplying extra load support when needed. The compressor kit contains a leveling valve similar to a semi-truck, when a load is applied the sensor allows the compressor to automatically fill the airsprings to maintain proper drive height allowing for a level and comfortable ride when hauling trailers, car trailers, RVs, and boats. Premium Fox Shocks, designed to improve ride quality, are also included in most TowPro packages. These shocks have custom valving for maximum ride comfort for loaded or empty loads.
Each TowPro kit is specifically designed for each vehicle application, and it is a completely bolt-on installation. Never has there been an easier way to improve the ride quality and load leveling of your truck trailing application.
The list of available applications is too large to list, but if you have a truck your interested in give us a call, I bet we have a kit available for your tow vehicle!
We will do Any complete kit for Any vehicle "Shipped" for $1,500.00
