So after installing the Scanmaster on my 87 GN we realized the TPS was off. (.44 idle and 3.6x WOT)
We attempted to set my factory sensor and after about 20 tries, realized that one of the ears was cracked off.
I bought a new Autozone sensor and same thing, the highest it would read is 3.6. We hogged out the mounting holes and the most we could get it to is 4.1 while still maintaining the correct idle setting. I tried disconnecting all the cables and opening the throttle blades by hand, no difference. It seems like the blade is opening the entire way. The only thing I didnt do was remove the charge pipe to make sure it was completely opening.
Any ideas?
Any ideas?
