TPS Adjustment
slide it forward on its mounting screws as far as it will go, then tip the front end up or down until the TPS voltage is .40-.44 with the throttle closed.
then verify how high it goes at WOT. Should be 4.2 volts or higher but is not as critical as the low end.
