87BuickMan
- Oct 4, 2006
hey all, have a quick question, finally got the car back together and am tring to adjust the TPS. Now with key on (not running) I pulled it as foward as possible, then snugged the screws, I then turned it upwards till I got a reading of .45 volts, so at that point I tightened the screws. Problem is when I got to WOT the volts jump to 10.5-11 instead of 4.8 or so. I was using the pedal inside the car, not just working it under the hood.
