I am having trouble setting my TPS at WOT. I can set key on at .40 easily. Then when I test for WOT the voltage reads around 3.90. Positioning the TPS to get anything over 4.0 sets the idle TPS voltage to greater than .50. If I ignore the idle setting and try to position to get the max voltage at WOT I can only get around 4.0 with the foot pedal. I can get 4.2 by operating the throttle by hand, but that is pushing very hard. It's as if the throttle doesn't have enough travel in it to attain the recommended 4.50 or higher volts at WOT.
It doesn't appear to be a TPS issue, as I swapped to a new one with the same results. The roll pin is not bent either.
Gonna get some expert help this weekend, but if anyone else has seen this I would appreciate your thoughts.
