Tps Tec Fix
larry33kc
I have a TPS TEC that has a wire that has pulled out and I would like to fix it but need ideas on how or what to use TIA
Well , don't take this the wrong way but , throwing it in the trash may be the best fix.
LOL....... it wasn't taken the wrong way, I would just like to get it fixed
The wire cam off from the prong inside the connector and I have to take it out before connecting the wire back to it.
So I need to find out how to take the connector out
If its the wire at the connector you need a weatherpack connector remover like this one that lisle makes
http://www.handsontools.com/store/show_product/?product_id=2481
then just insert the tool and it pushes out the terminal
to install after you either solder the wire on or replace the terminal just push the wire back in the connector .
