Dec 24, 2003 #1 L larry33kc Well-Known Member Joined Aug 19, 2001 Messages 1,714 I have a TPS TEC that has a wire that has pulled out and I would like to fix it but need ideas on how or what to use TIA
Dec 26, 2003 #2 T- Type Tim Vice Chairman Joined Jul 8, 2001 Messages 2,157 Well , don't take this the wrong way but , throwing it in the trash may be the best fix.
Dec 26, 2003 #3 L larry33kc Well-Known Member Joined Aug 19, 2001 Messages 1,714 LOL....... it wasn't taken the wrong way, I would just like to get it fixed
Dec 26, 2003 #4 P petesgn Banned Joined Nov 3, 2001 Messages 1,417 Have you tried to dig around where it broke then solder a new wire to it.
Dec 26, 2003 #5 L larry33kc Well-Known Member Joined Aug 19, 2001 Messages 1,714 The wire cam off from the prong inside the connector and I have to take it out before connecting the wire back to it. So I need to find out how to take the connector out
Dec 26, 2003 #6 P petesgn Banned Joined Nov 3, 2001 Messages 1,417 Originally posted by larry33kc The wire cam off from the prong inside the connector and I have to take it out before connecting the wire back to it. So I need to find out how to take the connector out Click to expand... If its the wire at the connector you need a weatherpack connector remover like this one that lisle makes http://www.handsontools.com/store/show_product/?product_id=2481 then just insert the tool and it pushes out the terminal to install after you either solder the wire on or replace the terminal just push the wire back in the connector .
