http://www.gnttype.org/maint/malf.html#21
CODE 21
Trouble Code 21 indicates that the Throttle Position Sensor (TPS) is reading abnormally high. TPS volts should be close to 0.42 V at closed throttle and rise smoothly in about 0.02 volt increments to a maximum reading of about 4.85 volts at WOT.
The conditions for setting this code are:
the engine is running, and
Code 33 or 34 (MAF error) is not set, and
TPS reading is > 4.90 volts
- or -
TPS reading stays between 2.5 and 4.9 volts, and
MAF reading is < 15 grams/second, and
the above two conditions are present for more than 5 seconds
Note: During a Code 21 condition, the ECM uses a default TPS value of 2.6 volts. This will cause the engine to idle very high.
Typical causes for this code include:
1) Defective TPS
2) Short circuit in the TPS harness to +5 volt reference
3) Open sensor ground circuit
4) Defective ECM
I like to adjust them for .42 and 4.60v.
