I been gathering info on the tps setting and find that .042-44 at idle and 4.5-.9 at wot if i remeber correctly. i went to check my tps and could not get a reading at idle (didnt try at wot) is there a different method of checking? I stuck the positive lead of my multimeter in the center wire slot on the harness and pushed in in all tghe way i think i didnt want to cut the wire so i didnt force it in any further. I loosened the screws a touch and tapped it gently to see if it was installed icorectly and still nothing. Now my Service engine light comes on at idle and goes off after i drive. No Tach, so im guessing the light goes off at around 1000-1200 rpms and comes on if i slow down to a stop. is my tps bad or can i move it around some more and try to get a reading. The car actually seems to be running better minus the light coming on, idles smoother runs smoother just the light comes on at lower rpms.
