smokin'6 said:
BTW, I see your mute about who the manual is in fact wrong with the MAT, IAT issue. Is that an admission on your part, that the manual isn't always right?.
As far as the sources you linked to how about asking them why the following data, proves, their in error. While having a TPS of 4.x might be the normal, or expected, it has nothing to do with actually enabling WOT/PE.
Having too low of WOT TPS, ie say 2v would min the amount of Accleration Enrichment, since that works on a delta TPS. So with out having much of a difference and/or large sweeps the AE would be off, but that's not PE mode.
As far as the min TPS to enable WOT/PE here's a actual log file that shows, that with this *prom*, that as you hit ~35% TPS, it switches commanded AFRs from 14.4 to 12.0... You can see, as I swept the TPS to various values, there's no change from 35% upwards in the sBPW (injector Pulse Width). I also repeated it at 3,000 RPM, and again, changing the TPS only allowed enabling WOT/PE, again at ~35%.
This code is somewhat different then the oem code used in the stock ecm, ie, it's been converted to MAP, and there's a special closed throttle VE table so that at certain conditions, the fuel is cut off when the TPS is closed, but as it opens, the sBPW starts again, and again the only thing the TPS does is switches commanded AFRs. The reason for the AFR getting richer is the Time in PE, enrichment table.
Obviously, you want the throttle to open completely, but the actual voltage at full opening isn't at all critical, for enabling WOT, other then if it's too high you'll set a code.
TimeStamp: 07/21/2005 - 22:15:59
EngRun Mph Rpm KPa Tps CtsF MatF VE% FSA sBPW AFR
02:05 0 850 93 0 160 95 67 16.5 5.98 14.4
02:05 0 850 94 1 160 95 67 18.0 6.07 14.4
02:05 0 850 94 2 160 95 62 16.5 5.71 14.4
02:05 0 850 94 2 160 95 62 16.5 5.80 14.4
02:05 0 850 94 4 160 95 62 16.5 5.80 14.4
02:05 0 850 94 5 160 95 64 16.5 5.80 14.4
02:05 0 850 94 8 160 95 64 16.5 5.71 14.4
02:05 0 850 94 10 160 95 62 16.5 5.71 14.4
02:05 0 850 94 11 160 95 62 16.5 5.71 14.4
02:05 0 850 94 12 160 95 62 16.5 5.80 14.4
02:05 0 850 93 13 160 95 64 16.5 5.80 14.4
02:05 0 850 94 15 160 95 64 16.5 5.80 14.4
02:05 0 850 94 15 160 95 64 16.5 5.71 14.4
02:05 0 850 94 18 160 95 62 16.5 5.71 14.4
02:06 0 850 94 19 160 95 62 16.5 5.71 14.4
02:06 0 850 94 19 160 95 62 16.5 5.80 14.4
02:06 0 850 94 20 160 95 62 4.2 5.71 14.4
02:06 0 850 94 22 160 95 62 4.2 5.71 14.4
02:06 0 850 94 23 160 95 62 4.2 5.71 14.4
02:06 0 850 94 24 160 95 62 4.2 5.71 14.4
02:06 0 850 94 25 160 95 62 4.2 5.80 14.4
02:06 0 850 94 26 160 95 62 4.2 5.80 14.4
02:06 0 850 94 27 160 95 64 4.2 5.80 14.4
02:06 0 850 94 29 160 95 62 4.2 5.71 14.4
02:06 0 850 94 30 160 95 62 4.2 5.71 14.4
02:06 0 850 94 31 160 95 62 4.2 5.71 14.4
02:06 0 850 94 33 160 95 62 4.2 5.80 14.4
02:06 0 850 93 33 160 95 64 4.2 5.80 14.4
02:06 0 850 94 35 160 95 64 4.2 5.71 14.4
02:07 0 850 94 36 160 95 62 4.2 5.71 14.4
02:07 0 850 94 38 160 95 62 4.2 6.53 12.0
02:07 0 850 94 39 160 95 62 4.2 6.53 12.0
02:07 0 850 94 40 160 95 62 4.2 6.71 12.0
02:07 0 850 94 41 160 95 64 4.2 6.53 12.0
02:07 0 850 94 42 160 95 64 4.2 6.53 12.0
02:07 0 850 94 43 160 95 62 4.2 6.53 12.0
02:07 0 850 94 44 160 95 62 4.2 6.53 12.0
02:07 0 850 94 44 160 95 62 4.2 6.71 12.0
02:07 0 850 94 45 160 95 62 4.2 6.53 12.0
02:07 0 850 94 46 160 95 62 4.2 6.53 12.0
02:07 0 850 94 47 160 95 62 4.2 6.53 12.0
02:07 0 850 94 48 160 95 62 4.2 6.71 12.0
02:09 0 850 93 55 160 95 64 4.2 6.71 12.0
02:09 0 850 94 55 160 95 62 4.2 6.53 12.0
02:09 0 850 94 56 160 95 62 4.2 6.53 12.0
02:09 0 850 94 56 160 95 64 4.2 6.53 12.0
02:09 0 850 94 57 160 95 62 4.2 6.53 12.0
02:09 0 850 94 57 160 95 64 4.2 6.71 12.0
02:09 0 850 94 57 160 95 64 4.2 6.53 12.0
02:09 0 875 94 57 160 95 64 4.2 6.53 12.0
02:09 0 850 94 58 161 95 62 4.2 6.53 12.0
02:09 0 875 94 58 161 95 62 4.2 6.53 12.0
02:09 0 850 94 58 160 95 62 4.2 6.71 12.0
02:09 0 850 93 58 160 95 62 4.2 6.71 12.0
02:09 0 850 94 58 160 95 64 4.2 6.53 12.0
02:11 0 875 93 66 160 95 64 4.2 6.71 11.9
02:11 0 875 94 67 160 95 64 4.2 6.62 11.9
02:11 0 875 94 67 160 95 62 4.2 6.62 11.9
02:11 0 875 94 68 160 95 62 4.2 6.62 11.9
02:11 0 875 94 69 160 95 62 4.2 6.81 11.9
02:11 0 875 94 69 160 95 64 4.2 6.81 11.9
02:11 0 875 94 69 160 95 62 4.2 6.62 11.9
02:11 0 850 94 69 160 95 62 4.2 6.62 11.9
02:11 0 875 93 70 160 95 64 4.2 6.81 11.9
02:11 0 875 94 70 160 95 62 4.2 6.62 11.9
02:11 0 875 94 71 160 95 62 4.2 6.62 11.9
02:11 0 875 94 72 160 95 62 4.2 6.62 11.9
02:13 0 875 94 87 160 95 62 4.2 6.62 11.8
02:13 0 875 94 88 160 95 62 4.2 6.62 11.8
02:13 0 875 94 90 160 95 62 4.2 6.62 11.8
02:13 0 875 94 91 160 95 62 4.2 6.81 11.8
02:13 0 875 94 91 160 95 62 4.2 6.62 11.8
02:13 0 875 94 92 160 95 62 4.2 6.62 11.8
02:13 0 875 94 93 160 95 62 4.2 6.62 11.8
02:13 0 850 94 94 160 95 62 4.2 6.62 11.8
02:13 0 875 94 95 160 95 62 4.2 6.62 11.8
02:13 0 875 93 97 160 95 62 4.2 6.81 11.8
02:13 0 875 94 99 160 95 64 4.2 6.62 11.8
02:13 0 875 94 100 160 95 62 4.2 6.62 11.8
02:13 0 875 94 100 160 95 62 4.2 6.62 11.7
02:13 0 875 94 100 160 95 62 4.2 6.90 11.7
02:15 0 875 94 100 160 95 62 4.2 6.71 11.6
02:15 0 875 94 100 160 95 62 4.2 6.90 11.6
02:15 0 875 94 100 160 95 64 4.2 6.90 11.6
02:15 0 875 93 100 160 95 64 4.2 6.99 11.5
02:15 0 875 94 100 160 95 64 4.2 6.81 11.5
02:15 0 875 94 100 160 95 62 4.2 6.81 11.5
02:15 0 875 94 100 160 95 62 4.2 6.99 11.5
02:17 0 875 94 100 160 95 64 4.2 6.81 11.4
02:17 0 875 94 100 160 95 62 4.2 6.81 11.4
02:17 0 875 94 100 160 95 62 4.2 6.99 11.4
02:17 0 875 94 100 160 95 62 4.2 6.90 11.3
02:17 0 875 94 98 160 95 62 4.2 6.90 11.3
02:17 0 875 94 94 160 95 62 4.2 6.90 11.3
02:17 0 875 94 89 160 95 62 4.2 6.90 11.3
02:17 0 875 94 84 160 95 62 4.2 6.90 11.3
02:17 0 875 94 79 160 95 62 4.2 6.90 11.3
02:17 0 875 94 75 160 95 62 4.2 6.90 11.3
02:17 0 875 94 71 160 95 62 4.2 6.90 11.3
02:17 0 875 94 69 160 95 62 4.2 6.90 11.3
02:19 0 875 94 37 160 95 64 4.2 6.90 11.2
02:19 0 875 94 36 160 95 62 4.2 6.90 11.2
02:19 0 875 94 35 160 95 62 4.2 6.90 11.2
02:19 0 875 94 34 160 95 62 4.2 6.90 14.4
02:19 0 875 94 33 160 95 64 4.2 5.71 14.4
02:19 0 875 94 31 160 95 62 4.2 5.71 14.4
02:19 0 875 94 30 160 95 62 4.2 5.71 14.4
02:19 0 875 94 30 160 95 62 4.2 5.80 14.4
02:19 0 875 93 29 160 95 62 4.2 5.80 14.4
02:19 0 875 94 27 160 95 64 4.2 5.71 14.4
02:19 0 875 94 27 160 95 62 4.2 5.71 14.4
02:19 0 875 94 26 160 95 62 4.2 5.80 14.4
02:19 0 875 94 25 160 95 62 4.2 5.80 14.4
02:19 0 875 93 24 160 95 64 4.2 5.80 14.4
02:20 0 875 93 24 160 95 64 4.2 5.80 14.4
02:20 0 875 94 23 160 95 62 4.2 5.71 14.4
02:20 0 875 94 22 160 95 62 4.2 5.71 14.4
02:20 0 875 94 21 160 95 62 4.2 5.71 14.4
02:20 0 875 94 20 160 95 64 4.2 5.71 14.4
02:20 0 875 94 20 160 95 62 4.2 5.71 14.4
02:20 0 875 94 19 160 95 62 4.2 5.71 14.4
02:20 0 875 94 19 160 95 62 6.0 5.71 14.4
02:20 0 875 94 18 160 95 62 7.7 5.71 14.4
02:20 0 875 94 18 160 95 64 9.5 5.71 14.4
02:20 0 875 94 17 160 95 62 11.6 5.71 14.4
02:20 0 875 94 16 160 95 62 13.4 5.71 14.4
02:20 0 875 94 16 160 95 62 15.1 5.80 14.4
02:21 0 875 94 15 160 95 62 16.5 5.80 14.4
02:21 0 875 94 15 160 95 64 16.5 5.80 14.4
02:21 0 875 94 14 160 95 64 16.5 5.71 14.4
02:21 0 875 94 13 160 95 62 16.5 5.71 14.4
02:21 0 875 94 12 160 95 62 16.5 5.71 14.4
02:21 0 875 93 12 160 95 64 16.5 5.80 14.4
02:21 0 875 94 12 160 95 64 16.5 5.80 14.4
02:21 0 875 94 12 160 95 64 16.5 5.71 14.4
02:21 0 875 94 11 160 95 62 16.5 5.71 14.4
02:21 0 875 94 10 160 95 62 16.5 5.71 14.4
02:21 0 875 93 9 160 95 64 16.5 5.80 14.4
02:21 0 875 94 9 160 95 64 16.5 5.71 14.4
02:21 0 875 94 8 160 95 64 16.5 5.71 14.4
02:22 0 875 94 8 160 95 62 16.5 5.71 14.4
02:22 0 875 94 7 160 95 62 16.5 5.71 14.4
02:22 0 875 94 7 160 95 64 16.5 5.80 14.4
02:22 0 875 94 6 160 95 62 16.5 5.71 14.4
02:22 0 875 94 6 160 95 62 16.5 5.80 14.4
02:22 0 875 93 6 160 95 64 16.5 5.80 14.4
02:22 0 875 94 6 160 95 64 16.5 5.80 14.4
02:22 0 875 94 6 160 95 64 16.5 5.71 14.4
02:22 0 875 94 5 160 95 62 16.5 5.71 14.4
02:22 0 875 94 4 160 95 62 16.5 5.80 14.4
02:22 0 875 93 3 160 95 64 16.5 5.80 14.4
02:23 0 875 94 2 160 95 64 16.5 5.71 14.4
02:23 0 875 94 2 160 95 62 16.5 5.71 14.4
02:23 0 875 94 2 160 95 62 16.5 5.80 14.4
02:23 0 875 94 2 160 95 64 16.5 5.80 14.4
02:23 0 875 93 2 160 95 64 16.5 5.80 14.4
02:23 0 875 94 1 160 95 62 16.5 5.71 14.4
02:24 0 875 94 1 160 95 62 16.5 5.80 14.4
02:24 0 875 94 1 160 95 64 16.5 5.80 14.4
02:24 0 875 94 1 160 95 64 16.5 5.71 14.4
02:24 0 875 94 1 160 95 62 16.5 5.71 14.4
02:24 0 875 93 1 160 95 62 16.5 5.80 14.4
02:24 0 875 93 1 160 95 64 16.5 5.80 14.4
02:25 0 875 94 1 160 95 62 16.5 5.71 14.4
02:25 0 875 94 1 160 95 64 16.5 5.80 14.4
02:25 0 875 94 1 160 95 64 16.5 5.71 14.4
02:25 0 875 94 0 160 95 62 16.5 5.98 14.4
02:25 0 875 93 0 160 95 67 16.5 5.98 14.4
02:25 0 875 94 0 160 95 67 16.5 6.07 14.4
02:25 0 875 94 0 160 95 67 16.5 5.98 14.4
02:26 0 875 94 0 160 95 67 16.5 5.98 14.4
02:26 0 875 94 0 160 95 67 16.5 6.07 14.4
02:28 0 850 94 0 160 95 66 15.5 5.98 14.4
02:28 0 850 94 0 160 95 67 16.2 5.98 14.4
02:28 0 850 94 0 160 95 67 16.5 6.07 14.4
02:28 0 875 94 0 160 95 68 17.6 6.07 14.4
02:28 0 900 94 0 160 95 68 18.3 6.07 14.4
02:28 0 950 94 0 160 95 69 20.1 6.17 14.4
02:28 0 1025 93 0 160 95 66 22.5 5.98 14.4
02:28 0 1025 94 0 160 95 61 23.6 5.34 14.4
02:28 0 1075 94 0 160 95 44 25.7 4.43 14.4
02:28 0 1100 94 0 160 95 35 26.8 3.78 14.4
02:28 0 1125 94 0 160 95 26 29.2 2.50 14.4
02:28 0 1300 93 0 160 95 0 31.7 0.00 14.4
02:28 0 1300 94 0 160 95 0 31.7 0.00 14.4
02:29 0 1300 94 0 160 95 0 31.7 0.00 14.4
02:29 0 1325 94 0 160 95 0 31.7 0.00 14.4
02:29 0 1375 94 0 160 95 0 31.7 0.00 14.4
02:29 0 1400 94 0 160 95 0 31.7 0.00 14.4
02:29 0 1425 94 0 160 95 0 31.7 0.00 14.4
02:29 0 1450 94 0 160 95 0 31.7 0.00 14.4
02:29 0 1525 94 0 160 95 0 32.4 0.00 14.4
02:29 0 1575 94 0 160 95 0 32.0 0.00 14.4
02:29 0 1600 94 0 160 95 0 32.0 0.00 14.4
02:30 0 1600 94 0 160 95 0 32.0 0.00 14.4
02:30 0 1650 94 0 160 95 0 31.7 0.00 14.4
02:30 0 1725 93 0 160 95 0 31.7 0.00 14.4
02:30 0 1725 94 0 160 95 0 31.7 0.00 14.4
02:30 0 1750 94 0 160 95 0 31.7 0.00 14.4
02:30 0 1800 94 0 160 95 0 31.7 0.00 14.4
02:30 0 1875 94 0 160 95 0 31.7 0.00 14.4
02:30 0 1900 93 0 160 95 0 31.7 0.00 14.4
02:30 0 1925 94 0 160 95 0 31.7 0.00 14.4
02:31 0 1950 93 0 160 95 0 31.7 0.00 14.4
02:31 0 1950 94 0 160 95 0 31.7 0.00 14.4
02:31 0 1975 94 0 160 95 0 31.7 0.00 14.4
02:31 0 2050 94 0 160 95 0 31.7 0.00 14.4
02:31 0 2075 94 0 160 95 0 31.7 0.00 14.4
02:31 0 2100 94 0 160 95 0 31.7 0.00 14.4
02:31 0 2125 93 0 160 95 0 31.7 0.00 14.4
02:31 0 2125 94 0 160 95 0 31.7 0.00 14.4
02:31 0 2225 94 0 160 95 0 31.7 0.00 14.4
02:31 0 2275 94 0 160 95 0 31.7 0.00 14.4
02:32 0 2275 94 0 160 95 0 31.7 0.00 14.4
02:32 0 2300 94 0 160 95 0 31.7 0.00 14.4
02:32 0 2350 94 0 160 95 0 32.7 0.00 14.4
02:32 0 2375 93 0 160 95 0 32.0 0.00 14.4
02:32 0 2400 94 0 160 95 0 32.0 0.00 14.4
02:32 0 2425 94 0 160 95 0 31.7 0.00 14.4
02:32 0 2475 94 0 160 95 0 31.7 0.00 14.4
02:32 0 2475 93 0 160 95 0 31.7 0.00 14.4
02:32 0 2500 94 0 160 95 0 31.7 0.00 14.4
02:32 0 2550 94 0 160 95 0 31.7 0.00 14.4
02:38 0 2975 94 0 160 95 0 28.5 0.00 14.4
02:38 0 3000 94 0 160 95 0 28.2 0.00 14.4
02:38 0 2975 94 0 160 95 0 28.2 0.00 14.4
02:38 0 2975 94 0 160 95 0 28.9 0.00 14.4
02:38 0 2975 94 1 160 95 0 29.9 0.00 14.4
02:38 0 2975 94 1 160 95 0 29.6 0.00 14.4
02:38 0 3000 94 1 160 95 0 29.9 0.00 14.4
02:38 0 3000 93 1 160 95 0 29.9 0.00 14.4
02:38 0 2975 94 1 160 95 0 30.3 0.00 14.4
02:38 0 3000 94 1 160 95 0 30.3 0.00 14.4
02:39 0 2975 94 2 160 95 68 26.8 6.07 14.4
02:39 0 2975 94 2 160 95 68 26.4 6.07 14.4
02:39 0 3000 94 2 160 95 68 26.4 6.07 14.4
02:40 0 2975 94 2 160 95 68 26.8 6.07 14.4
02:40 0 2975 94 2 160 95 68 26.4 6.07 14.4
02:40 0 3000 94 2 160 95 68 26.4 6.07 14.4
02:40 0 2975 93 2 160 95 68 26.8 6.07 14.4
02:40 0 3000 94 2 160 95 68 26.8 6.07 14.4
02:41 0 2975 93 2 160 95 68 26.8 6.07 14.4
02:41 0 3000 94 2 160 95 68 26.4 6.07 14.4
02:41 0 2975 94 2 160 95 68 26.4 6.07 14.4
02:41 0 3000 94 2 160 95 68 26.8 6.07 14.4
02:41 0 3000 94 2 161 95 68 26.4 6.07 14.4
02:41 0 2975 94 2 160 95 68 26.8 6.07 14.4
02:41 0 3000 93 2 160 95 68 26.8 6.07 14.4
02:41 0 2975 94 3 160 95 68 26.4 6.07 14.4
02:41 0 2975 94 3 160 95 68 26.8 6.07 14.4
02:42 0 2975 94 4 160 95 68 26.8 6.07 14.4
02:42 0 3000 94 5 160 95 68 26.4 6.07 14.4
02:42 0 2975 94 7 160 95 68 26.4 6.07 14.4
02:42 0 2975 94 8 160 95 68 26.4 6.07 14.4
02:42 0 3000 93 9 160 95 68 26.8 6.07 14.4
02:42 0 3000 94 9 160 95 68 26.8 6.07 14.4
02:42 0 2975 94 9 160 95 68 26.4 6.07 14.4
02:42 0 3000 94 10 160 95 68 26.4 6.07 14.4
02:42 0 3000 94 11 160 95 68 26.4 6.07 14.4
02:42 0 2975 94 11 160 95 68 26.4 6.07 14.4
02:42 0 2975 93 12 160 95 68 26.8 6.07 14.4
02:42 0 2975 94 13 160 95 68 26.4 6.07 14.4
02:42 0 3000 94 14 160 95 68 26.4 6.07 14.4
02:42 0 3000 94 15 160 95 68 26.4 6.07 14.4
02:42 0 2975 94 15 160 95 68 26.4 6.07 14.4
02:43 0 2975 94 16 160 95 68 26.4 6.07 14.4
02:43 0 2975 94 16 160 95 68 26.8 6.07 14.4
02:43 0 3000 94 17 160 95 68 26.8 6.07 14.4
02:43 0 2975 94 18 160 95 68 26.4 6.07 14.4
02:43 0 3000 94 18 160 95 68 26.4 6.07 14.4
02:43 0 2975 94 19 160 95 68 26.4 6.07 14.4
02:43 0 2975 93 19 160 95 68 26.8 6.07 14.4
02:43 0 2975 94 20 160 95 68 26.8 6.07 14.4
02:43 0 3000 94 20 160 95 68 11.3 6.07 14.4
02:43 0 2975 94 21 160 95 68 11.3 6.07 14.4
02:43 0 2975 94 23 160 95 68 11.3 6.07 14.4
02:43 0 3000 94 23 160 95 68 11.3 6.07 14.4
02:43 0 2975 94 24 160 95 68 11.6 6.07 14.4
02:43 0 3000 94 25 160 95 68 11.6 6.07 14.4
02:43 0 3000 94 25 160 95 68 11.3 6.07 14.4
02:44 0 2975 94 26 160 95 68 11.3 6.07 14.4
02:44 0 3000 94 26 160 95 68 11.3 6.07 14.4
02:44 0 2975 93 27 160 95 68 11.6 6.07 14.4
02:44 0 2975 94 27 160 95 68 11.3 6.07 14.4
02:44 0 2975 94 29 160 95 68 11.3 6.07 14.4
02:44 0 2975 93 29 160 95 68 11.6 6.07 14.4
02:44 0 2975 94 29 160 95 68 11.6 6.07 14.4
02:44 0 3000 94 30 160 95 68 11.3 6.07 14.4
02:44 0 2975 94 31 160 95 68 11.3 6.07 14.4
02:44 0 2975 94 31 160 95 68 11.6 6.07 14.4
02:44 0 3000 94 32 160 95 68 11.6 6.07 14.4
02:45 0 2975 94 33 160 95 68 11.6 6.07 14.4
02:45 0 3000 94 33 160 95 68 11.3 6.07 14.4
02:45 0 2975 94 33 160 95 68 11.3 6.07 14.4
02:45 0 2975 94 34 160 95 68 11.3 6.07 14.4
02:45 0 3000 93 34 160 95 68 11.6 6.07 14.4
02:45 0 3000 94 35 160 95 68 11.6 7.08 12.0
02:45 0 3000 94 36 160 95 68 11.6 7.08 12.0
02:45 0 2975 94 37 160 95 68 11.3 7.08 12.0
02:45 0 3000 94 38 160 95 68 11.3 7.08 12.0
02:45 0 2975 94 38 160 95 68 11.3 7.08 12.0
02:45 0 3000 94 39 160 95 68 11.3 7.08 12.0
02:45 0 2975 94 39 160 95 68 11.3 7.08 12.0
02:46 0 3000 93 40 160 95 68 11.6 7.08 12.0
02:46 0 3000 94 40 160 95 68 11.6 7.08 12.0
02:46 0 3000 94 41 160 95 68 11.3 7.08 12.0
02:46 0 2975 94 42 160 95 68 11.3 7.08 12.0
02:46 0 3000 93 42 160 95 68 11.6 7.08 12.0
02:46 0 3000 94 42 160 95 68 11.6 7.08 12.0
02:46 0 2975 94 43 160 95 68 11.3 7.08 12.0
02:46 0 3000 94 44 160 95 68 11.3 7.08 12.0
02:46 0 2975 94 44 160 95 68 11.3 7.08 12.0
02:46 0 3000 94 46 160 95 68 11.6 7.08 12.0
02:46 0 2975 94 46 160 95 68 11.6 7.08 12.0
02:46 0 3000 94 47 160 95 68 11.3 7.08 12.0
02:47 0 3000 94 48 160 95 68 11.3 7.08 12.0
02:47 0 2975 94 49 160 95 68 11.3 7.08 12.0
02:47 0 2975 94 50 160 95 68 11.3 7.08 12.0
02:47 0 3000 94 51 160 95 68 11.3 7.08 12.0
02:47 0 2975 94 51 160 95 68 11.3 7.08 12.0
02:47 0 2975 94 52 160 95 68 11.3 7.08 12.0
02:47 0 3000 94 53 160 95 68 11.3 7.08 12.0
02:47 0 3000 94 53 160 95 68 11.6 7.08 12.0
02:47 0 2975 93 53 160 95 68 11.6 7.08 12.0
02:47 0 2975 94 54 160 95 68 11.6 7.08 12.0
02:47 0 3000 94 55 160 95 68 11.3 7.08 12.0
02:47 0 3000 94 56 160 95 68 11.6 7.08 12.0
02:49 0 3000 94 65 160 95 68 11.6 7.08 12.0
02:49 0 3000 94 66 160 95 68 11.6 7.08 12.0
02:49 0 3000 94 67 160 95 68 11.3 7.08 12.0
02:49 0 2975 94 68 160 95 68 11.3 7.08 11.9
02:49 0 3000 94 68 160 95 68 11.3 7.08 11.9
02:49 0 2975 93 69 160 95 68 11.6 7.08 11.9
02:49 0 3000 94 69 160 95 68 11.6 7.08 11.9
02:49 0 3000 94 71 160 95 68 11.3 7.08 11.9
02:49 0 2975 94 72 160 95 68 11.3 7.08 11.9
02:49 0 3000 94 74 160 95 68 11.3 7.08 11.9
02:49 0 2975 94 76 160 95 68 11.6 7.08 11.9
02:49 0 3000 94 77 160 95 68 11.6 7.08 11.9
02:49 0 3000 94 78 160 95 68 11.3 7.08 11.9
02:49 0 2975 94 80 160 95 68 11.3 7.08 11.9
02:49 0 3000 94 80 160 95 68 11.3 7.08 11.9
02:51 0 2975 94 100 160 95 68 11.3 7.17 11.8
02:51 0 2975 93 100 160 95 68 11.6 7.17 11.8
02:51 0 3000 94 100 160 95 68 11.3 7.17 11.8
02:51 0 3000 94 100 160 95 68 11.6 7.17 11.8
02:51 0 2975 94 100 160 95 68 11.6 7.17 11.8
02:51 0 3000 93 100 160 95 68 11.6 7.17 11.8
02:53 0 3000 94 100 160 95 68 11.3 7.26 11.6
02:53 0 3000 93 100 160 95 68 11.6 7.26 11.6
02:53 0 3000 94 100 160 95 68 11.6 7.26 11.6
02:53 0 2975 93 100 160 95 68 11.6 7.26 11.6
02:53 0 3000 94 100 160 95 68 11.6 7.26 11.5
02:53 0 3000 94 100 160 95 68 11.3 7.36 11.5
02:53 0 2975 94 100 160 95 68 11.3 7.36 11.5
02:55 0 3000 94 75 160 95 68 11.6 7.36 11.4
02:55 0 3000 94 73 160 95 68 11.6 7.36 11.4
02:55 0 2975 94 71 160 95 68 11.3 7.36 11.4
02:55 0 3000 94 69 160 95 68 11.3 7.36 11.4
02:55 0 3000 94 68 160 95 68 11.3 7.36 11.4
02:55 0 2975 94 65 160 95 68 11.3 7.36 11.4
02:55 0 3000 94 64 160 95 68 11.3 7.36 11.4
02:55 0 2975 94 63 160 95 68 11.3 7.36 11.4
02:55 0 3000 94 61 160 95 68 11.3 7.36 11.4
02:55 0 3000 94 59 160 95 68 11.3 7.45 11.3
02:55 0 3000 94 58 160 95 68 11.3 7.45 11.3
02:55 0 2975 94 57 160 95 68 11.3 7.45 11.3
02:55 0 3000 94 57 160 95 68 11.3 7.45 11.3
02:55 0 3000 94 56 160 95 68 11.3 7.45 11.3
02:57 0 2975 94 42 160 95 68 11.3 7.45 11.3
02:57 0 2975 94 41 160 95 68 11.3 7.45 11.3
02:57 0 3000 94 40 160 95 68 11.3 7.45 11.3
02:57 0 3000 94 39 160 95 68 11.3 7.45 11.2
02:57 0 3000 94 38 160 95 68 11.6 7.45 11.2
02:57 0 2975 94 38 160 95 68 11.3 7.45 11.2
02:57 0 2975 94 37 160 95 68 11.3 7.45 11.2
02:57 0 3000 94 36 160 95 68 11.3 7.45 11.2
02:57 0 2975 94 36 160 95 68 11.6 7.45 11.2
02:57 0 3000 94 35 160 95 68 11.6 7.45 11.2
02:57 0 3000 94 35 160 95 68 11.3 7.45 11.2
02:57 0 2975 94 35 160 95 68 11.3 7.45 11.2
02:57 0 3000 94 34 160 95 68 11.3 7.45 11.2
02:57 0 2975 93 34 160 95 68 11.6 7.45 11.2
Yes, I edited down, by leaving the time stamps....
