TR6 Troublecode Reading?
greeneyegi
been finally putting miles on car and was messing with the IAC settings through XFI. I shut oft and now no spark.
Put in different tune and nothing.
I found screw fell out of cam sensor. Replaced and tested no good.
TR6 I believe is coding, but don't know how to read the code, and search is down.
TR6-Tried to start, all 3 leds fire except for run, then i get a red light for a second then pause and red light blinks 8 times then repeats on the tr6.
The xfi leds i get green power/crank goes red solid/cam orange solid/points flicker during start, any help would be appreciated. I really think its something in the XFI I fd with.
From the manual... Hope this helps?... Mike
So that'd be code #18 your getting...
Yes that’s what I got out of it, hmm I’ve got Casper’s engine wiring kit with tr6.
Weird all the sudden .
I checked ccci fuse 25a, it’s good.
Never saw the coil Hotwire thing before. Guess I’ll get to trying that.
Thanks for replies, but I removed the plug @TR6 and everything is perfect, I checked the Caspers extender etc and all is good.
Checked Voltage at "M" and 7v. when turning over it goes down to 3v.
When the plug is undone it goes to 12 on M wire.
Going to put straight 12v to "M" and see what happens.
this should be the CCCI Hotwire system . Ill report back
