SignUp Now!I like someone else's quote on topics like this.
"crickets"
My guess would be that most 6765 guys are running low 11's/high 10's (because they don't have the combo to go faster - they overbought in turbo just like the 6776 craze) and most 6768 guys (probably just a few out there) are running mid to low 10's. Otherwise, they'd bought a 70 or 71 to run some easier 9's - as if 9's were easy in the first place.
If you really plan on maxxing out one, then plan on probably 132-134mph for a 6765, 138-142 with a 6768.
I realize that both turbos are rated for more HP. And the original 70gtq/hpq is continuing to prove that it has more power potential than anyone ever imagined, but for the rest of us common folk, it's hard to see that we'll be able to max out a turbo like the faster TSM/TSO guys.
Maybe a vendor will chime in with better info, but I doubt they've have had customers to max out either turbo before stepping it up.
Hope that's helpful anyway.
Of course they do. Any T3 can run a tangential 4 bolt. Id go HPS if i was running a T4 housing and want to be able to make some real good power.I'm going 4 bolt next season. Do they have a 4 bolt housing for the new Billet Turbos??? I'm between the proven 70GTQ or one of the new billet turbo's. I will also have a few more cubes next year.
We recently removed a CPT70BB with Ptrim froma customers car and installed a billet 6765 with 63 housing. car went from 125MPH to 130MPH at the same boost (around 28) low 10.70's to high 10.30's I ported the turbine housing before we installed it and we can get rock solid boost with a HD actuator no creep problems, this is with pump gas and alky.
Mike
What's the rest of the supporting cast for that car?
Do you have any incrementals for bot setups? Just wondering where the ET improvement came in...... on the front end..... back end.... or everywhere...
Id bet that converter was eating at least 3mph there, maybe 4mphIt is better everywhere, especially on the street, at the track the biggest gains were in the second 1/8, biggest problem is now we are going through the converter or the car would be even faster. I knew the billet 67 would be better I very suprised how much better it was.
Mike
Journal bearing or aircooled bb?We recently removed a CPT70BB with Ptrim froma customers car and installed a billet 6765 with 63 housing. car went from 125MPH to 130MPH at the same boost (around 28) low 10.70's to high 10.30's I ported the turbine housing before we installed it and we can get rock solid boost with a HD actuator no creep problems, this is with pump gas and alky.
Mike
