Details of the run:
60' - 2.102
330' - 5.763
1/8 - 8.807
MPH - 80.48
1000' - 11.449
1/4 - 13.682
MPH - 100.78
Turbo Trans Am #850
EMPTY WEIGHT:????(leather/t-top car)
BLOCK:stock
HEADS:stock
CAM:stock
TRANSMISSION:stock
TORQUE CONVERTER:stock
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:no
INJECTORS:stock
THERMOSTAT:stock
TURBOCHARGER:stock
VALVE SPRINGS:stock
MAF:stock
DOWN PIPE:stock
EXHAUST:stock
FUEL PUMP:stock
FUEL PRESSURE REGULATOR:stock
FUEL PRESSURE:stock(45psi?)
ALCHOHOL INJECTION:no
PROPAIN INJECTION:no
NITROUS:no
AIR FILTER AND AIR INTAKE:stock
TIRE DESIGN, SIZE & AIR PRESSURE:stock size radials
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:none
FUEL:93 octane
CHIP:stock
CHIP TIMING:stock
KNOCK RETARD:??
OXYGEN SENSOR VOLTAGE:???
EXHAUST GAS TEMPERATURE:???
TRACK ELEVATION:E-Town,NJ(near sea level)
TEMPERATURE:76*
PEAK BOOST:stock(16.5?)
BOOST AT LAUNCH:0(2000 rpm launch)
MILES ON THE CAR/ENGINE:59,000
This was my first time racing a TTA and the only time I took this car to the track.I'm sure with just a good spring cleaning this car would be low 13's easy.It's bone stock down to the paper air filter![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
Steve
60' - 2.102
330' - 5.763
1/8 - 8.807
MPH - 80.48
1000' - 11.449
1/4 - 13.682
MPH - 100.78
Turbo Trans Am #850
BLOCK:stock
HEADS:stock
CAM:stock
TRANSMISSION:stock
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:no
INJECTORS:stock
THERMOSTAT:stock
TURBOCHARGER:stock
VALVE SPRINGS:stock
MAF:stock
DOWN PIPE:stock
EXHAUST:stock
FUEL PUMP:stock
NITROUS:no
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:none
FUEL:93 octane
CHIP:stock
CHIP TIMING:stock
KNOCK RETARD:??
TEMPERATURE:76*
Steve
