johnplogii
Senior citizen
- Aug 13, 2005
As the title says I am having a problem getting traction this year. Last year I was running a te44 everything else in sig the same. All stock non boxed control arms w/factory bushings, 50/50 drag shocks & one bag. The car ran consistant 7.20's @ 95 eighth mile with consistant mid 1.50 60 fts, with a best of 1.52. I put the 67 on in nov & only got two passes but one was a 1.56 60ft. All this was on eight year old m/t 26 x 10 x 15 slicks. Over the winter I added a six point cage (80 lbs worth) harnesses (20 lbs) removed 20 lbs, new m/t 28 x 12.50 x 16 et streets (m5 compound wrinkle wall 10 inches wide) tranny w/transbrake, re-stalled the convertor from 0 pump to 6 pump (vigilante). This year my car runs consistant 6.90's & 7.00's with 60fts in the mid to high 1.60's. I have gotten two 1.59's but I have also gotten some 1.70's. I have installed umi solid lowers and umi relocation brackets using the lowest setting. I also bought umi adjustable uppers & just put them on yesterday. haven't been to track yet. Oh yeah, the car also now runs 100-101mph. I feel it has the power to get mid 1.40 60fts I just need some help from the experts on how to get there.
I usually launch the car at 15-20lbs off the t-brake resulting in the 60fts above. From videos it looks like it hooks at first pulling the left tire about 6 inches off the ground, then 5-10 feet out it drops & spins. Any help is appreciated, sorry this was so long
