Jan 19, 2002 #1 T Turboaddict Guest when bolting back the bolts, do you start at the middle and work your way out to the sides in criss cross fashion or just go around?
Jan 19, 2002 #2 M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Messages 3,658 Assuming you're talking about the valve body bolts, yes that is a good way to do it. Also, do not over-torque them; err on the loose side. The threads in the case can get fragile and valve body bores can distort.
Jan 19, 2002 #4 M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Messages 3,658 With the pan bolts, sequence doesn't really matter. Again, proper torque is important to avoid distorting the pan rail or crushing the gasket.
