Tranny cooler Feed/Return Ports?
Hot Air
E85 and S.E./Carolinas Moderator
Staff member
Which of the two ports is the feed to the cooler? The upper port of lower port?
Conrad
On mine the bottom one on the rad is the inlet to the rad, but make sure by disconnecting one of the lines at the rad and put a pop bottle over the line and a cup in front of the rad hole and have someone fire the car up for just a second. It is important to get the flow right and this is a sure way to tell.
