Tranny Cooler Fitment Question.
HighMileage
Albany,NY
Does anyone here have an aftermarket cooler that fits against/attaches to the AC condenser,but fits behind the cross-bars that are in the rad support?
I know Imperial makes coolers,as well as Hayden. (?)
I want to install a large one between the condenser and those X/cross-bars.
Thanks.
I put my B&M cooler right where you want to put yours. I just fabbed up a new radiator support out of some 5/16" rod. Figure out your offset, heat it up, bend it, flattened the ends, drill some holes, paint it black and your all set. I flattened the middle where the 2 rods cross also. Put in any size cooler you want...
this is how i mounted my Gm cooler , similar to the way they did the gnx
I just took the support rods off and put them in a box
I did checked out the one on EBay, and yes very nice set up, but also expensive for something that is very simple to install. I fabricated my own version of bracket by using "U" shape pipe clamp and 1/4" nylon washers between the tranny cooler and the "U" shape clamp. Although the tranny cooler I have gave me just enough hose to routed in two direction. Overall, this tranny cooler installation work out great.
