Tranny Mating Connector
salvageV6
Daily Driver
Anyone know what type of 4 pin connector is on the transmission?
I would like to make up a cable to test the TCC wiring inside the tranny without working under the car.
Is it the same connector as the IACV? I know it's 4 pins square.
Manufacturer name and model of the connector would be helpful if known. :)
TIA
The particular division of GM that made these was called Packard Electric Division or P.E.D. P.E.D. was then folded into Delphi which was subsequently sold off from GM a couple years ago.
The TCC connector is basically the same as the IAC connector but the terminals are 'keyed' to fit only certain female counterparts. A couple sources for the connector your hunting would be Howell Engine Developments or Casper Electronics.
Thanks just needed to know it was a Packard. :)
We test the IACV's in the lab next to mine, they should have the pins at least so I can make a plug in harness even if I don't find the right exact shell.
I was thinking it was something rather standard. Great!
