Apr 11, 2009 #1 Q Quiky One Active Member Joined Dec 31, 2005 Messages 8,079 Who sells a new tranny mount and the little bushings that connect the crossmember? thanks Jason
Apr 11, 2009 #2 G Grumpy Thread killer Joined May 24, 2001 Messages 13,825 I used NAPA tranny mounts .. Jan Larsen should know the bushing #s from GM
Apr 12, 2009 #4 J Jan Larsson Active Member Joined Nov 22, 2001 Messages 2,151 Yep as always Dan is right .... GM still have the tranny crossmember bushings .... you need 3 of each #547702 and #547704 I also use the Napa trans cross member bushing (at the rear) ...
