who did trans? make sure it has filter in it .who installed converter? if pump is turning you think you would have some pressure. pull of line at rad and have someone start the car and shut it off real fast and see if fluid comes out. if no fluid comes out you may have a pump problem.was converter hard to turn when installing bolts?
