josh rosaaen
- Nov 29, 2012
What trans brake would everyone recommend? My 60ft is horrible and can't get it to build boost off the line. What's a good trans brake and how long or hard is the install on them?
SignUp Now!If it was the correct camshaft and it was set up correctly there's very little downside to it but we don't have the info yetI am with Bison get rid of that 224 camshaft , I had one it was a dog and caused me all kind of problems till I went smaller
I only ran the 1/8th but I'll check the slip when I get homewhat was your MPH at the 1/8 and 1/4
you did not spin the tires cant believe it was that slow to spool
Id like to see the MPH
Order a 19 or 20 blade PTC from Dusty Bradford. You will need 5600-5700 stall at full hit with you comboI've been looking for headers also. Pry going to switch them out with something other then the stock so I don't have to deal with the Cracking. What stall would you recommend for the converter. The car is going to be mainly a street car only do about 4 trips a year to the track.
