trans brake (shifter bracket)?
ozmossis
anyone have any idea, who sells the (shifter bracket) you use when using a trans brake, the bracket that will not let you car shift into neutral after shifting out of low one. if anyone can help thanks, i know someone made thease a few years back just cant remember who?
Steve, it's not to hard to modify the factory shifter plate. I did some cutting and installed a heavier spring on mine over the winter, now it will lockout in DRIVE.
G-Bodyparts is where I got mine along with upgraded J-rod.
Mike
G- Body parts and Mark Hueffman sell them.
I have some as well.
Brian
