stickybones
What?
- Dec 27, 2001
Can someone tell me how I can have a trans fluid "leak" at the radiator that puddles in the radiator support below the radiator drain petcock but my trans coolant lines going to and from the radiator are dry? Is the entire coolant circuit within the radiator submerged in coolant? Can it leak internally and not contaminate the coolant and then just leak out the radiator end tank? My antifreeze/coolant looks perfect lime green color with no signs of trans fluid contamination. My lower radiator hose also has trans fluid on it.
This is driving me crazy. The leak is so bad that it's dripping off the petcock and leaving a spot on the ground but my coolant lines appear bone dry. The trans coolant lines also enter the radiator on the front side, but the signs of the leak are on the back side of the radiator.
Why can't I ever figure out what's wrong with this car.
I can now see why many people just give up and sell them.
