trans cooler?
blackbox
Hey guys i was installing my front mount and had to move this thing. It looks like an old tranny cooler. It was mounted on a bar that crossed right where the intercooler is going to go. So i took it off and now woundering where everyone else puts there tranny cooler if thats what it is. Heres a pic of the thing. Im not going to use it again if its a tranny cooler. Ill most likely buy a new version
looks like a nice tranny cooler. i wouldnt replace it. just clean it,flush it and run it.
really, dont know much about trans coolers. Ive seen some with fans and stuff. This one i dont know how old it is but its lines run directly to the transmission. I thought they were suppose to go to the rad. My trans has never given me problems except for a bad TC solenoid. If its still good i might just mount it somewere else and redo the hoses. Thanks for the reply
i ran my lines straight to my cooler and one point. now i run my fluid threw the radiator then the trans cooler then back to the tranny.
thats the way mine was installed, straight to the trans cooler. I noticed my car also has oil cooler lines going to the radiator. I have two ports on the front side of the radiator facing the intercooler but there is no room to use those. How can i connect this cooler and the oil together?
If that is a tranny cooler, that is the "MAC DADDY" of coolers. With one that size, I wouold say forget the rad tie in and just run that beast straight to tranny. For a street car, you should have no trouble. I believe running all that heat thru your rad makes it less effective in engine cooling. I am going to run external oil and tranny. Frame rail mounted oil and tranny in front of rad. You should be able to sandwich that between your front mount and rad.
If you are in doubt, contact your tranny guy and get his input.
Coach
thats how it was connected. I dont know how long previous owner had it like that but ive driven the car for 3 years with it connected straight to tranny with no problems. This is when the car was driven daily to work. Now its a weekend car so if it dosnt matter ill keep it the way it is. I only thought about changing because everyone else runs it through the rad.
