UR50SLO
The Reaper
- Jun 12, 2001
Hey.. just wanted to say all is well with the trans that you built for Paul Brumbaugh for his Buick Powered Camaro so far. He said it shifts firm and all the gears are there!
Our last build lasted 200miles
With luck having all the gears we might break into the 10s on pump gas through the mufflers on 14lbs/boost with ET Streets.
The best pass it made last year was a 11.31@114mph.. the run was cut short by excessive RPM's with out 3d gear.
Thanks again, Scott and Paul
