trans gasket
jlat
hello peoples: I was just reading about different types of oil pan gaskets.
How about trans pan gaskets? I guess mine is old as there is a load of trans fluid under my car now. The car has been sitting for the winter and maybe a trans gasket is needed?
What do you think when I drop the pan any thing I can or should do besides the screen? I do have a stock screen a a deeper pan.
IBBY
Most of the Builders recommmend the Duraprene pan gaskets.
Install a 700R4 filter if you use the Deep pan. A new TCC Solenoid is also a good idea while the Pan's down.
how to do you know if the TCC Solenoid is going bad or breaking down?
hello: SSedan64 you got that CK book on the 200r didn't you? What kind of advise doesn it give for a HP street TB?
IBBY
IBBY
It has about everything to do with the 2004R, not TB specific builds.
Probably the most important thing for use behind a Turbo engine would be initial line pressure rise. Lot's of torque at light/low throttle positions compared to N/A engines. :eek::biggrin:
