trans line pressure fluctuations @ idle in low 1 and low 2 ,rest pretty steady??
syclone01
put ck kit in my 39k mile car. installed correctly.
car now leaks fluid from vent tube.......checked trans level etc...
In the following gears at idle pressure is:\
P steady 75psi, give gas shoots up quickly to 200-250
R goes briefly to about 50psi then up to 115psi pretty steady
N instantly to 75 steady
OD slight 5-10psi drop, then 75psi pretty steady
D slight 5psi drop, then 75psi pretty steady
Low2 goes to about 165 fluctuates 150---175 rapidly, while holding brake and giving gas to around 1100-1200rpm goes to about 210psi with fluctuation of about 10-15psi
Low1 goes down to 150 fluctuates 145-170, while holding brake and giving gas to around 1100-1200rpm goes to about 210 with 10-15psi fluctuation...
FLuid is coming out vent tube. Got under car with light and inspection mirrow, watched fluid leak out vent tube with car on 4 jackstand level, while running. Tried different levels of trans fluid, still seems to still leak out.
Any ideas on anything I should check?? Getting tired of taking pan off car.
thanks, damon carter
