65malibuss
- Dec 8, 2001
I have an art carr 9" 3000 stall non lockup tc and an art carr shift kit (for non lockup converter). Shift kit is from CPT Transmission, purchased about 3 months ago.
If I start out in Drive or Overdrive, the rpms go up to 3000-3500, boost goes up, but car is very slow and I can hardly feel it shift from 1 to 2, 2 to 3, 3 to 4.
However, if I start in 1st gear with part throttle or WOT, the car is fast, and when I shift to 2nd at 3000-4000 rpm it shifts fast and hard, then when I shift to 3rd it shifts fast and hard.
So it seems that the trans is slipping and shifting early when I let it shift itself but if I shift it manually it doesn't feel like it's slipping at all and the car flies and shifts great.
I tried resetting my TV cable a few times by pushing button in, pulling cable towards firewall, letting button go, and pushing gas pedal to floor, but I don't think that could be the problem if everything works fine when shifting manually.
Any advice or idea of what the problem could be?
Thanks.
Thanks.
