Trans lines reversed at radiator cooler (250 deg problem)
buickboy
Trying to track down the trans temp going to 250, i found the pressure line going into the radiator trans cooler at the bottom and return line at the top. When i disconnected the top line, no fluid was present (no dripping). Is this a plugged cooler or is the direction of the fluid flow a problem in the radiator cooler? I have it bypassed to my aux cooler at the moment and have not tested it yet. Any thoughts Bruce?
Mitch
