TRANS PRO users ?'s
fast eddie
Senior Member
my temp gauge reads 85* all the time,Why?
My eng is a .20 over rebuild should i change size of motor from 3.8?
also were do you go from basic tune,and how and were to start?
More to come
Thanks, Ed
which temp?
.020 overbore won't make enough of a difference, just leave it 3.8
What's the rest of the setup?
Bob
The Scanmaster will not show air temperature, the air temp sensor is being used by the Translator Pro to calculate airflow. So the Translator Pro sends a constant temperature signal to the ECM instead.
Which chip are you using?
Bob
Extender
Extender chip,should I get a pro Chip? what are the advantages of the Pro chip?How much to re burn chip?
Thanks Bob!
Ed
Thanks Bob!
Ed
The Pro chip allows you to control spark advance with the Translator Pro.
Otherwise it is basically the same as the extender.
Contact Mike at Fullthrottle for upgrade details.
Bob
