I have been doing some digging and this is what I came up with...2004-2007 Pontiac Grand Prix GTP L32 Supercharged engine rated at 260 HP. Any thoughts on this setup ??
There is a Series II and a Series III engine and the difference is where the injectors are located Vince. You need to look at them and see which it is. If they're in the intake you're fine but if they're mounted into the head then it's a Series III set up and you can't make it a RWD very easily. I've got the correct heads and intake that I will be playing with later to mount them on a RWD block. The intake will be cut apart so I can make my own for a draw through system.
