my85grandnation
85 Triple Threat
- Mar 12, 2004
On my 85 T-Type once the car is warmed up the trans starts acting up and it wont kick down from a higher gear if you floor it or say start up a hill. It will just stay in the higher gear and bog down and finally it will drop down with a big clunk. It only happens after its hot though. While its cool it shifts and downshifts just fine. I was thinking the TV cable was out of adjustment but just readjusted it and it seems fine. Ive had the trans flushed and have an aftermarket aluminum radiator with trans cooler built in but it doesn't seem to help. I'm thinking its a heat issue but what would it be causing this a solenoid or something valve body wise? Could it still be the TV cable? This started happening after we had an engine put in the car. Has anyone ever had anything like this happen?
