L
		larryc
Guest
Hey guys,
I got a serious problem with my 200 trans in my t-type that I can't solve and I need some solid advice. This trans has less than 400 miles since Kent Rudbeck Rebuilt it. I know he does a good job on them and I am totally satisfied except it will not shift at wide open throttle about 90% of the time. The 10% of the time it will shift is when the trans is not real hot. I tried the tv cable adjustment and changed fluid and filter and checked to make sure the spring is still in the gov. as stated in prev. posts. When it does shift, its at 6100 rpm or it will bounce off the rev limiter then it will shift sometimes. I tried leaving it in second gear and manually shifting it and that does not work either. I talked to kent at Bristol and he said to look at the pump spring. When I changed the fluid there was some metal in the bottom of the pan but I thought it normal. PLEASE HELP
Thanks,
Lawrence
Thanks,
Lawrence
