- Jun 28, 2001
Is anyone using the transbrake creep option on the xfi to stage their car?
I have several customers using this feature. Look at last years videos of the TSO class.Is anyone using the transbrake creep option on the xfi to stage their car?
Allan I like your idea. I just got my XFI and I would like to connect it as well. I think the Arm is a Negative Ground! Can someone tell me how it is connected.. This means their are 2 switches applied?I wired mine in the cruise control stalk switch. I tested it but never actually used it at the drag strip .
AG
Cal, do you suggest using the XFI over the Boost Leash creep feature? I didnt order the Boost Leash with the feature but was going to send it in over the winter to have it added. Is there better control on one vs the other?I have several customers using this feature. Look at last years videos of the TSO class.
Well since I am going to be connecting my gauges to the XFI inputs I might as well use the XFI to do the trans creep. I will PM you when I attack it.Sorry Brian. I missed your previous post. Both the XFI and the Leash work well. The XFI is smoother. The Leash is a simpler install and probably a little easier to set up. The XFI is free other than the digital relay.
