Ok I am in the midst of swapping an '87 IC engine into my '84 T-type, this is my situation, and I would appreciate your opinions...
First of all, I have no stock intake parts, so this will be a completely fresh setup. Also, I have a Power Logger (if that makes any difference).
The options:
1. Translator Pro with speed density setup, 4" pipe w/ 9" k&n filter.
2. Translator GenII w/ LS1 maf, 3.5" pipe w/ 9" k&n.
3. Any cheaper alternatives???
I've done a bit of research on these options, but I'm still a little hazy on the details. I know the Trans Pro requires a MAP sensor, but does it need a wide band O2 sensor as well? What else is required for this to work (ecu chip, etc)? And what is the purpose of a Wide band O2?
The Translator GenII obviously requires a LS1 MAF, and I see that those can be pretty expensive.
What setup would you go with based on an hp to $$$ ratio?
The options:
