translator + ?
GBGN1
stroked
Ive got a 4.0 version-----------how do i change between the 3 and 3.5 -maf settings im useing a 3 inch and on the cover it sayes 1-5 for size setting but i dont know how or if the size setting is right or how to adjust?
thanks
Brian
Mine is version six but it should be the same
Base maf
0-3.5" Sensor
1-3.5" Sensor rich idle
2-3.5" Sensor lean idle
3-3" Sensor
4-3" Sensor rich idle
5-3" Sensor lean idle
6-85mm Sensor
7-85mm Senson rich idle
8-85mm Sensor lean idle
HTH
Also....you are not limited to just picking the number to the corresponding MAF. For example, I just played around with the settings till I found one that provided the proper idle and then double checked the BLMs on WOT. For my LS6 MAF (factory screenless) I ended up using a base setting of 7 and have no problems.
Just FYI - hope that helps!
Is there an adjustment in the trans + ,that that you need to do to the trans plus to change for the 3 inch or 3.5 inch maft-(is there physically a knob or switch to switch from a 3 or 3.5 ich maft?----cause for right now i have a 3 inch and want to know if the trans+ is set right.
Brian
Here's a pic for ya
Hey thanks alot--so the base maft setting coencides with the maft size --
k thanks
again
Brian
