Transmission and Convertor ID?
54Rich
My recently aquired WE4 does not have the correct transmission in it. The lock up plug is disconnected. Does anyone have any idea of what I have?
Here's all I know, the tag ID is 219-861KCF001
Can someone please decode this?
Also, the TC is Blue? How can I tell what it is, is it marked?
Thanks, very new to Automatics, used to 4 Speeds:cool:
Thanks,
Rich
Attn: Brian Hoffer
Rich, Maybe brian will chime in and give us some input on the trans & TC. Scot w.
kt is a horrible calibratrion for the turbo 6.it looks as if someone swapped out the original unit.there is really no way to id the tc after is rebuilt.apperars to be a stock diameter.are there any numbers stamped into it?stickers?
KT:confused: You lost me there.
I'll try and see if I can find anything on the converter numbers wise. I'll be droping the pan soon for a fluid change. Is it possible to have the correct valve body. Seems to shift strong and clean.
Anyone close to the Twin Cities have the correct core?
Thanks,
Rich
It is possible it has the correct valvebody and governor. Check to see if the valvebody is a BR2 or BR3. If you can, post a picture of the governor. Someone may have changed the case for some reason or it is the wrong transmission for a turbo car.
Here's all the informaion I could dig up. At least it has a fresh filter and fliud.
Thanks,
Rich
Great link, Thanks
That would aslo explane why the speedo is so far off. Anyone know what color gear I should have with a 3.42 rear? The one that's in there is black.
Again Thanks,
Rich
