Transmission cooling lines
T
tc86gn
Guest
I have finally found the correct lines for this car. for all that are looking,go to...www.classictube.com Here you can order any trans line. The lines even came with the small ones that go around the radiator to the front. One problem... I do not have and i am unable to find the 2 90degree fittings that go in the radiator coolant ports. everything I find is pipe thread on one end. And when you just bend the lines, they either kink, or rub on the AC condenser.... Any suggestions or help would be greatly appreciated. Thank you in advance.
Tom
Find someone to bend you a set. I lot of local shops can do it too. Hell you can if you buy the right stuff. We have a guy at a NAPA store that is a bending guru. A spring bender and flare tool is all ya really need, but if your not handy there are people who can do it.
I bought a set from Poston.Already to go.It fit right on the money..
