Transmission Filter Recommendations.
HighMileage
Albany,NY
Which filter is a quality filter?
Is there a difference between a discount store filter from Advance,and one from NAPA?
I've heard that Wix makes a good filter. I'm not sure if they actually manufacture tranny filters.
Any suggestions appreciated. Thanks!
P.s.. I already searched and found the right way to install the pan so that it doesn't seep.
There all chinese/mexico made these days. All the same .. Just do yourself a favor and use the early 700 model filter and double up your pan gaskets. Done deal
I shortened the oil transfer tube on the valve body 1/4 inch on each end to get the 700 filter up closer to the valve body . Don't know if this is absolutely necessary but I didn't need to double up on the pan gasket . Just make sure to insulate the 4th gear pressure switch terminal since the 700 filter is wider and might ground the switch .
