Transmission Pump
84GNwith87eng
I'm looking to buy a new trans pump, cause mine is leaking badly. I see they go for $195 on Postons site, which seems high but they come with a lot.
Is there anywhere else I can get a pump that is a little bit cheaper costwise but still is decent for a mild setup?
thanks
Chris
poston sells our pumps.the pump is only expensive when you compare it to a stock type rebuilt pump.the pump is an important part of your 2004r.this is not the place to try to save a few dollars.
