GNVYUS 1
- Dec 15, 2002
150 to 160 temps are now the norm.
Pusher Fan runs all the time.
Temps were 180-190 with a similar sized cooler and the fan on the liquid ic pulling on it through both cores.
I believe the 2nd fan (pusher) being on all the time helped the most.
PTC 9.5" 17 blade spragless was pretty rough on the temps but this update helped a lot. Even on hot days high 150s to low 160 until you hit it hard, then it gradually comes back down.
I don't run the cooler lines through the radiator.
I don't have an FMIC, trans cooler gets first shot at in coming air (both temps).
XHP Transmission Cooler (Hayden) $80
30,000 GVW
11" x 11-5/8" x 3/4"
Derale $80
Straight Blade Electric Fan
8" Diameter
350 CFM
If I had only 1 fan, I'd run a bigger fan size and make it a puller 1st.
30,000 GVW
Derale $80
8" Diameter
350 CFM
