usually called the delphi / Zo6 . use the 85mm setting . and youll need an adapter or do some wiring from the 5 pin on that maf to the 3 pin ,
i wouldnt use the temp sensor , casper has adapter for plug and play
its slightly under 4" outside but works with 4" couplers
