Truck sensor #15904068 with translator
usually called the delphi / Zo6 . use the 85mm setting . and youll need an adapter or do some wiring from the 5 pin on that maf to the 3 pin ,
i wouldnt use the temp sensor , casper has adapter for plug and play
its slightly under 4" outside but works with 4" couplers
the air temp sensors in the 85mm mafs is close enough to stock to use. But, yes, set the translator to "85mm maf"
Bob
