Trunk mount battery supplies...
Squid4life
I remember checking out a few of you guys' cars that had trunk mounted batteries when we had the Fuddruckers get together and was wondering if you guys found a local place that sells good cable or if you got it online. I am looking for something similar to welding cable that is fine strand, large gauge cable.
Any local spots?
visit
local welding supply, or Napa, ask for welding cable, "0"or "00" depends on how long the run will be, you can ground to the frame, in the rear, but add additional grounds up front, ( to starter, or block) using larger ground cable.
use propane torch to melt solder to attach cable ends, (do not crimp em)
good luck
cruzn57
