GREG O'Brien
- Aug 19, 2002
I'm a Ford 2.3L guy - but I figured I'd poke around here since you guys know alot more about PTE than I do.
I am a little confused by PTE's HP ratings... i would REALLY like to know the #/min airflow, surge limit, maximum pressure ratio, and efficiency percentages for their turbos.
I have emailed them several times and they always say they'll get back to me later and that they can't release the actual maps because of an agreement with Garrett
so here is where i am confused
they have the SC50 rated at 445hp - but it appears to be a T04E-50 garrett compressor based on the spec sheets which has a max airflow of 49 #/min - seems conservative to me.
they have the TA/TE/SC-32 rated at 485hp - but it appears to be a T04E-57 garrett compressor based on the spec sheets which has a max air flow of 49#/min too - so that seem a okay.
they have the TA/TE/SC-34 rated at 545hp - but it appears to be a T04E-54 garrett compressor based on the spec sheets which has a max air flow of only 44#/min - so that is out of left field...
then they have the TA/TE/SC - 44, 51, and 53 which all appear to MAYBE be varied combinations of T04B-H with either a T31, a GT350, or a T04E turbine wheel.
and there is also the TA/TE/SC - 60, 52, and 54 which all appear to be varied cominations of the 60-1 with either a T31, a GT350, or a T04E turbine wheel.
My biggest questions center around:
1) where do they get these HP measurements - since they don't seem to relate directly to the max airflow of the turbo?
2) does there "custom" compressor housing have any major effect on the surge limit, efficiency, or maximum pressure ratio of the turbo?
the SC50 has the efficiency, pressure ratios and surge limit that i want - but it doesn't appear to flow enough and is rated at low HP.
the SC34 has the efficiency, pressure ratios, HP level I want, but the map says it really doesn't flow much and it has a FUNKY surge limit.
the SC60 has the flow and hp level i want - but according to the maps it has is a little short on effective pressure ratio, it isn't very efficient, and it could have a better surge limit for my "little" engine
any insight or experiences...
i could really use some answers.
GREG
GREG
