SignUp Now!Turbo
* • Single 3-bolt turbo only.
• Maximum size compressor wheel inducer size is less than 71mm. Inlet bore cannot exceed 71.5mm to allow for machining tolerances. Maximum compressor wheel exducer size is less than 103mm.
• No sleeves, welding or cold weld epoxy on any exterior surface of the turbo compressor housing to allow a larger than “70mm” compressor wheel to be installed is allowed.
• One of the following turbine exhaust housings is allowed: A Garrett P/N's 430832-4 and 430832-5, PT&E P/N's THB376, THB380, THB576 and THB580, Turbonetics P/N's 20240-63 and 30340-82 3 bolt turbine housings that were available November 1 of the previous year. The FSA turbine exhaust-to-downpipe flange connection must be used.
• Any air intake to turbo allowed.
• Any wastegate configuration acceptable, external wastegate(s) must be plumbed back into the exhaust system, no external dumps allowed.
• CO2 allowed for wastegate actuator.
Not sure, but I think there was something that was too big on the 71...not sure though.
Is the Billet HPQ-70 or 71 available? Don't they have to be available to everyone by a certain date to be legal for the season?
Sully
Yep... with the plug.![]()
The billet 70MM compressor wheel measures 70.5mm (inducer) and 102.5mm (exducer). So far we like the results we have seen.![]()
As far as the rules, we have that covered. :wink:
Tony, I hear there will be good deals on popcorn at tech with proceeds going to payouts.
Who is We? Are you running?
How about you, gonna make it this year
So, if there is some type of new turbo, and the general public does not have access to it....it would be illegal? Right?
Hmmm... Harry has publically stated the billet 71 is illegal for TSM. :wink:
