TT chip
Grandn2
I have this chip in my car now but I've upgrade my turbo and converter from factory to a te60 & 2800. My mechanic told me I need a new chip and he doesn't know if the chip is adjustable. Can anybody tell me if it's adjustable or do I need a new chip
That chip IS adjustable
Wot fuel
Wot timing
Wot fuel 1,2 gears
Wot Timing 1,2 gears
Go to Turbotweak.com for the instructions.
and yes i would also get a new chip burned for the new combo.
I wouldn't want to loose an engine over $85.00
i would ask eric what he recommends, but for now you can add some WOT fuel just to be safe, i wouldnt go too crazy with your foot just yet tho- keep an eye on your 02's
I haven't got it tuned yet since I'm breaking the motor in. the most I seen was 7lbs of boost
Asking Eric is a good idea. Supply him with that chip number also. I would add about 7% to parameter 1 which is wide open throttle fuel in all gears like posted previously. Add that fuel and crank it to 15-16 psi. How's the oil pressure?
Oil pressure is at 80 at first start up. Around 40 at idle and 60 on throttle. Where do I get wot fuel
