TT6.1 chip users
tford
Registered Member
Can someone with their wideband tracking turned off send me a screenshot of the block grid from the powerlogger? I am confusing the adjustable parameters with the afr settings and am afraid to run my car until I figure this out. Where do I select the afr settings? In the 6.1 directions, it shows the grid with the top two rows at 128 and the bottom two rows
1 2 3 4
5 6 7 8
which are highlighted yellow. Clarify my confusion and post a screen shot with explanation please.
Thanks, Tim
I attached the description of the parameters to this post as a PDF.
The boxes marked 1 through 8 are parameters 1 through 8, which are all the user adjustable parameters.
Parameters 1 and 2 will typically default to 10.8 (108), parameter 3 will be 9.9 (99). The rest will be 128.
Let me know if you have any questions.
