1989 TTA Car #343
64,1XX miles
Everything in car is working, gauges etc, boost gauge is not as accurate so there is an aftermarket one in place. No accidents or anything.
First the bad things
Bad stuff
Small patch of what looks like painted over rust on front quarter panel on passenger size
about the size of a half dollar piece
Rear hatch motor was not working so it is manual now, still opens from inside car but you close like a regular trunk instead of the motor pulling it the rest of the way down
Exterior has a few small dents on doors, and scratch over the edge of the pace car sticker on the door
Small oil leak from rear of intake
Crack in rear wing like all TTAs
Good Stuff
Engine (3K miles)
Balanced and blueprinted bottom end
Stock crank std/std etc
Shot peened stock rods on stock pistons with file fit rings
High volume oil pump
204/214 speedpro cam
ARP head bolts
Heads and intake are port matched, backcut valves, LT1 springs
Stock TB and plenum with RJC power plate
Brand new sensors installed throughout
50lbers
Adj fuel pressure regulator
Double roller timing chain
Exhaust
PT51 Turbo with .63 housing
ATR stainless downpipe and crossover
ATR stainless exhaust system with cutout
Transmission/drivetrain
Stock 9 Bolt rear
Stock wheels
New Front tires
Rears are used but not that worn down
Brakes/Suspension
Cross drilled front rotors
Global west tubular subframe connectors
Line Lock installed center console
Electronics
Autometer boost gauge
Hotwire walbro pump
Volt booster
Extender chip
LS1 MAF
Translator(forget if its the plus or not)
Transmission has 0 miles on it and after installation will have approximately 40. It is rebuilt with CKperformance Stage 2 kit and has a new forward drum. Both front seats are brand new and hand sewn, they were 1k each and in excellent condition and no one has sat in them (covered in plastic) Car has been wet sanded and the paint is very bright now.
With my price I will include the following extra parts to help you along:
Owners Kit
Magazines/Articles of the TTA
Brand New Model Car of TTA scale 1/25
Baseball style Card of TTA
Case of Royal purple motor oil
Case of rear differential fluid and GM additive
Brand New Hawk performance brake pads for front
New Coolant Sensor
Brand New Transmission Oil cooler
With this condition and this amount of money into it I will be looking for 14,500 or best cash offer ( I can work with cash offer so please make one and we can go from there)
My email is Cleaner07@aol.com
car is garage kepted and only has about 1500 miles on it since me buying it in May over a year ago.
Looking to sell fast as my insurance payment for it is arriving in a month or so
thanks
Carl
64,1XX miles
Bad stuff
Good Stuff
Engine (3K miles)
ARP head bolts
50lbers
Exhaust
Stock 9 Bolt rear
Stock wheels
New Front tires
Brakes/Suspension
Electronics
Hotwire walbro pump
Volt booster
Extender chip
LS1 MAF
Owners Kit
New Coolant Sensor
thanks
Carl
