Paul Bellisario
- Feb 25, 2013
Any tips on hoe you guys set it up and mounted a front mount? and pics?
yeah i have the duty neck right now. but if i am planning to upgrade the ic might as well go all out. so i would to the front mount and yea i would probably end up cutting the front bumper it won't be a big deal bc it is spidering and needs work anyways
Yeah that good but the most effective way for performance would be to cut it. otherwise you won't be getting the same effect from the air under the noseIf you can find a DeQuick TTA front mount .. they don't cut the front bumper
alright so I would have to get a shroud custom made then
looks sweet! what is the ic mounted on to?
Too bad this kind a of crap has happened...Mease, Terry Houston and Tony DeQuick all went down the drain...interesting thread on the CAS (DeQuick) V4 stock location ($899.00 in 2002 ) and V2 front mount group buy debacle that went south http://www.turbobuick.com/forums/threads/cas-tta-intercooler-group-purchase.36527/
On another note...Steve's V2 front mount on TTA850 how it looks with the bumper off and how little room and ground clearance there is...I'm guessing Steve also removed the AC.
View attachment 215642 View attachment 215643 View attachment 215644
I have ac. If u use the gn ac lines it works perfect I run a 4 core aluminum radiator and twin fan set upToo bad this kind a of crap has happened...Mease, Terry Houston and Tony DeQuick all went down the drain...interesting thread on the CAS (DeQuick) V4 stock location ($899.00 in 2002 ) and V2 front mount group buy debacle that went south http://www.turbobuick.com/forums/threads/cas-tta-intercooler-group-purchase.36527/
